Question Users can not post new topic in 7.0.4
6 days 15 hours ago #234987 by Silencer2010
In Kunena 6, it was not a problem to disable the Kunena Profiles within the plugins, as we do not require them. In the current version of Kunena 7, however, this is no longer possible. If we disable the Kunena Profiles in the plugin, members are unable to create new topics; the error "0 Call to undefined method Kunena\Forum\Libraries\Integration\KunenaProfile::getProfileName()" appears. This was not an issue in Kunena 6. Is there a way to disable the profiles in Kunena 7 ??
6 days 13 hours ago #234988 by xillibit
We are not aware of this issue, i will look later to find a fix it. I'll get back to you once I've found a fix
6 days 10 hours ago #234989 by Silencer2010
Ok. Thank you. I already thought that this could be a bug perhaps.
5 days 17 hours ago #234992 by xillibit
I have made a fix for it yerstayday : github.com/Kunena/Kunena-Forum/commit/57...4a6b7dba428c8d3f2354 , it will be in the 7.0.6 version
5 days 16 hours ago - 5 days 16 hours ago #234993 by Leen
Tested on 2 sites, seems to work well.
update
Sorry, I was too quick to say that it works well.
If I set it to yes again in the Kunena - Kunena Integration plugin, the forum stops working; it shows
Fatal Error was detected!
The error was detected in the Kunena - Kunena Plugin.
Fatal Error: Declaration of Kunena\Forum\Plugin\Kunena\Kunena\Helper\KunenaProfileKunena::getProfileName(Kunena\Forum\Libraries\User\KunenaUser $user, string $visitorname = '', bool $escape = true): string must be compatible with Kunena\Forum\Libraries\Integration\KunenaProfile::getProfileName(Kunena\Forum\Libraries\User\KunenaUser $user, $visitorname = '', $escape = true): string in plugins/kunena/kunena/src/Helper/KunenaProfileKunena.php on line 189
Please contact the site owner.
With kind regards
Leen
Last edit: 5 days 16 hours ago by Leen.
5 days 11 hours ago #234994 by xillibit
Time to create page: 0.265 seconds
