Question Missing square bracket in TopicItemDisplay : 582
7 months 3 weeks ago #234855 by Gindi
In /components/com_kunena/src/Controller/Topic/Item/TopicItemDisplay, I noticed that on line 582
 $matches = preg_match("/\[img]http(s?):\/\/.*\/img]/iu‘, $message, $title);
 either there is one too much closing square bracket after the first “img”, or the opening square bracket is missing before the second “img”.
7 months 3 weeks ago #234856 by xillibit
hello,
Thanks for the report, i will check to see if it's need a fix
7 months 3 weeks ago #234858 by Gindi
If this is a bug that affects the protected function, it has persisted unchanged across all Kunena versions since Kunena 3
 /components/com-kunena/controller/topic/item/display.php :476
 $matches = preg_match(‘/\[img]http(s?):\/\/.*\/img]/iu’, $message, $title);
gindi
7 months 3 weeks ago #234859 by xillibit
I have checked it and it catch right the image with the bbcode tags so it's not an issue
