Question Fail on Kunane
10 months 1 day ago - 10 months 1 day ago #234399 by Hifi2you
Replied by Hifi2you on topic Fail on Kunane
Last edit: 10 months 1 day ago by Hifi2you.
10 months 1 day ago #234400 by Hifi2you
I dont think i can do this myself. Will that be corrected in the next update ?
Or is there a guide to du it ?
10 months 1 day ago - 10 months 1 day ago #234401 by xillibit
Replied by xillibit on topic Fail on Kunane
Some others people said that put 0 for the setting "Visible Thank You Limit", they understood that then none thank you should be displayed. So it's an expected behavior and as such not a bug.
In others languages maybe it's confusing
Last edit: 10 months 1 day ago by xillibit.
10 months 1 day ago #234402 by Hifi2you
Maybe there is some misunderstanding due to the language, but I haven't changed anything besides updating when an update has been released.
And now it doesn't show who clicks on "Thank you".
I assume it has always been at 0 since I haven't changed anything there.
Is 0 = infinity or should I set it to, for example, 10,000 ?
I simply don't understand why the name isn't shown if it's not an error
But thanks
10 months 21 hours ago #234403 by rich
Replied by rich on topic Fail on Kunane
It is correct as it is. With this value (default is 10), you only specify the number of users that are displayed under the post. If this number is exceeded, the following is displayed, for example (example with the value 4,  if 30 users have said thank you):
The following user(s) said Thank You: rich, xillibit, Gindi, Hifi2you and 26 other people also said thanks.
10 months 21 hours ago #234404 by Hifi2you
I just tried changing it to 10 and it shows as before.
I just set it to e.g. 50.
But thanks for that, now it seems to work
