Question Kunena 7.0 Installation
10 months 3 days ago - 10 months 3 days ago #234305 by Gindi
I attempted to install Kunena 7.0.0 via the Joomla updater, but received the following message: danger
Invalid extension update
I then installed the downloaded installation files in the backend via “System / Extensions / Upload Package File.”
Kunena 7 was not displayed in the backend / Notifications as expected, but in a new window called 3rd Party.
Is this now the new standard or is it a bug?
Gindi
Last edit: 10 months 3 days ago by Gindi. Reason: Name
10 months 3 days ago #234306 by xillibit
Replied by xillibit on topic Kunena 7.0 Installation
If you was on K6.4.8 i haven't yet modified the update files to allow the update to K7.0.0, i'am going to do it now.
On which version you was before the update ?
10 months 3 days ago #234307 by Gindi
Replied by Gindi on topic Kunena 7.0 Installation
I was on Joomla 6.0.2 and Kunena 6.4.8
Gindi
10 months 3 days ago - 10 months 3 days ago #234308 by xillibit
I have allowed to Joomla! updater to show Kunena 7.0.0 for users which are on K6.4.8.
I have tested on a site which was on K6.4.8, Joomla! updater shows Kunena 7.0.0 and then the update was done with issues.
Last edit: 10 months 3 days ago by xillibit.
10 months 3 days ago - 10 months 3 days ago #234311 by Gindi
I have now reinstalled Kunena 7.0 using the Joomla installer. Kunena is still displayed as a third-party installation on the admin page. The cache directory contains “com_kunena_configuration” with two files.
When I log in on the user page, the following message appears: The requested page could not be found.
At the bottom it says:
If you encounter any problems, please contact the administrator of this website.
0 Class “JPagination” not found
gindi
Last edit: 10 months 3 days ago by Gindi. Reason: Sätze sortiert.
10 months 3 days ago #234320 by Gindi
I created a new test version with the Lifesite update and installed Kunena 7.0 with the Joomla updater.
In the backend, Kunena is still 3rd party.
I activated debug and error reporting.
In the frontend, the error “The requested page could not be found” appeared again when logging in.
The error “0 Class ‘JPagination’ not found” was also displayed.
The call stack showed “uddeim” as the error.
After deactivating the “uddeim Mailbox” module, I was able to log in to the frontend as normal.
It was not a Kunena error.
gindi
