Question Creating own Kunena-Templates
11 months 2 weeks ago #234223 by fmdev
Hi.
Is there any documentation or guidance available on creating your own Kunena (not Joomla) template?
So that it can also be installed/uninstalled/managed via the Kunena menu.
11 months 2 weeks ago #234225 by Pinkeltje
Global instructions (might not be 100% accurate) and you should be aware that custom templates need a lot of maintenance as some template files are subject to change with Kunena versions. You might want to check existing Kunena templates .
  1. Understand Kunena Template Structure: A Kunena template is essentially a folder (e.g., my_kunena_template) within your Joomla components/com_kunena/template directory, containing CSS, JS, images, and layout overrides.
  2. Start from an Existing Template: copy Aurelia as a base for modification.
  3. Customize Files:
        CSS: Modify scss files in assets folder for styling.
        HTML/Layouts: Edit files in the layouts folder for layout changes (e.g., category/list/default.php, message/item/default.php).
  4. Create or modify template.xml and kunena_tmpl_aurelia.xml (rename to your own template name): This XML file describes your template to Joomla (name, version, author, files to install) and is crucial for installation.
  5. Package as a ZIP: Zip the entire template folder (e.g., my_kunena_template) into a single .zip file.
The following user(s) said Thank You: lemur
7 months 1 week ago - 7 months 1 week ago #234915 by lemur
Replied by lemur on topic Creating own Kunena-Templates
Global instructions
  1. Create or modify template.xml and kunena_tmpl_aurelia.xml (rename to your own template name): This XML file describes your template to Joomla (name, version, author, files to install) and is crucial for installation.
Hello.
Does your guide on creating a template also apply to Kunena 7?
I haven’t managed to get my custom template to work on Kunena 7.0.3 and Joomla 6.0.4 (I tried Kunena 7.4, but ran into issues and reverted to 7.0.3).
I copied the Aurelia folder, modified the two manifests in it (template.xml and kunena_tmpl_mykunenat.xml), created a .zip file, and installed it, but I ran into problems again on my local WAMP server.
So I decided to conduct a clean experiment. I created a fresh Joomla 6 site on Joomla.com, installed Kunena 7.0.3 there and installed mykunenat.zip.
But I found that my template simply wouldn’t become the default.
Is there something wrong with my manifests, or is there something else that needs to be done additionally somewhere? Or is this a Kunena issue?
template.xml:
<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE kinstall>
<kinstall type="kunena-template" version="4.0" method="upgrade">
     <name>mykunenat</name>
    <version>1.1</version>
    <creationDate>2026-04-19</creationDate>
    <author>author</author>
    <authorEmail>[email protected]</authorEmail>
    <authorUrl> geschichte-chronologie.de </authorUrl>
    <copyright>GPL</copyright>
    <license>GNU/GPL</license>
    <description>Useful Template for Kunena 7 (based on Aurelia)</description>
    <thumbnail>template_thumbnail.png</thumbnail>
    <targetversion version="7.0" />
</kinstall>
kunena_tmpl_mykunenat.xml:
<!DOCTYPE kinstall>
</kinstall>Is there something wrong with my manifests, or is this a Kunena issue?
Thank you.
Signature:
Many thanks to Rich and the other advisors.
Last edit: 7 months 1 week ago by lemur.
7 months 6 days ago #234916 by 9themestore
Hi @lemur,
If possible, please send me your custom template. I will help you edit it and possibly install it on the Kunena component. My emai: 9themestore[at]gmail.com
Kind regards,
