- Thank you received: 2
Topics must relate to a currently supported version of Kunena. If you are unsure what is the current supported version of Kunena, please go to the
download
page.
Question Kunena kills "page heading"
1 year 3 weeks ago #233882
by Bearsampp
Kunena kills "page heading" was created by Bearsampp
If you look at
ku2j5.alisonmeeks.com/
you'll see a green bar "page heading" This exists on ALL pages except kunena. Turning on "page heading" for kunena menu "forum" menu item did not restore it. How do I restore the page heading?
- 9themestore
- Premium Member
1 year 3 weeks ago #233883
by 9themestore
Replied by 9themestore on topic Kunena kills "page heading"
From your website's admin click to the "System -> Global Configuration -> Menus" menu. Turn on the "Show Page Heading" field in the "Page Display" tab.
- Thank you received: 162
1 year 3 weeks ago #233884
by Pinkeltje
Replied by Pinkeltje on topic Kunena kills "page heading"
As far as I can see the options to show page heading is missing in Kunena. You could make an override for components\com_kunena\template\aurelia\layouts\page\default.php
by changing code starting line 23
into
<div id="kunena" class="layout <?php echo $this->options->get('pageclass_sfx'); ?>">
<?php
<?php if ($this->options->get('show_page_heading',1)) : ?>
<h1><?php echo $this->options->get('page_heading') ? $this->options->get('page_heading') : KunenaFactory::getApplication()->getMenu()->getActive()->title; ?></h1>
<?php endif; ?>
<?php
The following user(s) said Thank You: 9themestore
1 year 3 weeks ago - 1 year 3 weeks ago #233887
by Bearsampp
Replied by Bearsampp on topic Kunena kills "page heading"
I tried to make an override and it didn't work.
postimg.cc/D8KTxvdX
I even tried editing aurelis directly and that didn't work either.
I don't mind making another template but I can't figure out how to upload a zip.
I'd prefer the override method. What am I doing wrong?
postimg.cc/D8KTxvdX
Last edit: 1 year 3 weeks ago by Bearsampp.
- 9themestore
- Premium Member
1 year 3 weeks ago #233888
by 9themestore
Hi Bearsampp,
The reason why the override doesn't work is that you copied the wrong folder structure. You can override Kunena's layout file with the following folder structure: [Your_Joomla_Template]/html/com_kunena/layouts/page/default.php.
Kind regards,
Kind regards,
1 year 3 weeks ago - 1 year 3 weeks ago #233891
by Bearsampp
Thats still not correct. If you examine
ku2j5.alisonmeeks.com/forum
you'll see a full width green bar. This is the .page_heading according to .css
That bar does not exist on kunena page. Adding the code you guys gave does add a heading ( seen by the 3 - above index ) but thats not the same thing as showing the "page_heading" like the rest of the site does.
The green bar is whats missing and needed.
This is being generated by
in index.php in the template I believe.
<?php if($option == 'com_content'){ ?>
<div class="page_heading">
<div class="wrapper960">
<?php if (!empty($params->get('page_heading')) && ($params->get('show_page_heading'))) { ?>
<h1><?php echo $params->get('page_heading'); ?></h1>
<?php } ?>
</div>
</div>
<?php } ?>
The following user(s) said Thank You: ssnobben
Time to create page: 0.219 seconds
