Question Kunena kills "page heading"
1 year 3 months ago #233882 by Bearsampp
If you look at  ku2j5.alisonmeeks.com/ you'll see a green bar "page heading"  This exists on ALL pages except kunena.  Turning on "page heading" for kunena menu "forum" menu item did not restore it.  How do I restore the page heading?
1 year 3 months ago #233883 by 9themestore
From your website's admin click to the "System -> Global Configuration -> Menus" menu. Turn on the "Show Page Heading" field in the "Page Display" tab.
1 year 3 months ago #233884 by Pinkeltje
As far as I can see the options to show page heading is missing in Kunena. You could make an override for components\com_kunena\template\aurelia\layouts\page\default.php
by changing code starting line 23
<div id="kunena" class="layout <?php echo $this->options->get('pageclass_sfx'); ?>">     <?php
into
<div id="kunena" class="layout <?php echo $this->options->get('pageclass_sfx'); ?>"> <?php if ($this->options->get('show_page_heading',1)) : ?>     <h1><?php echo  $this->options->get('page_heading') ? $this->options->get('page_heading') : KunenaFactory::getApplication()->getMenu()->getActive()->title; ?></h1> <?php endif; ?>     <?php
The following user(s) said Thank You: 9themestore
1 year 3 months ago - 1 year 3 months ago #233887 by Bearsampp
I tried to make an override and it didn't work.
postimg.cc/D8KTxvdX
I even tried editing aurelis directly and that didn't work either.
I don't mind making another template but I can't figure out how to upload a zip.
I'd prefer the override method.  What am I doing wrong?
Last edit: 1 year 3 months ago by Bearsampp.
1 year 3 months ago #233888 by 9themestore
Hi Bearsampp,
The reason why the override doesn't work is that you copied the wrong folder structure. You can override Kunena's layout file with the following folder structure: [Your_Joomla_Template]/html/com_kunena/layouts/page/default.php.
Kind regards,
1 year 3 months ago - 1 year 3 months ago #233891 by Bearsampp
Thats still not correct.  If you examine  ku2j5.alisonmeeks.com/forum you'll see a full width green bar.  This is the .page_heading according to .css
That bar does not exist on kunena page.  Adding the code you guys gave does add a heading ( seen by the 3 - above index ) but thats not the same thing as showing the "page_heading" like the rest of the site does.
The green bar is whats missing and needed.
This is being generated by
                 <?php if($option == 'com_content'){ ?>         <div class="page_heading">             <div class="wrapper960">             <?php if (!empty($params->get('page_heading')) && ($params->get('show_page_heading'))) { ?>                 <h1><?php echo $params->get('page_heading'); ?></h1>             <?php } ?>             </div>         </div>     <?php } ?>
in index.php in the template I believe.
The following user(s) said Thank You: ssnobben
