Kunena 7.0.8 Released
Question Can't get Kunena to work - would appreciate any help/tips
1 year 2 weeks ago #233869 by Vlietpark
Hi, I'm André, 68 y/o, reasonably omputer savvy, but sometimes struggling with joomla 5 and some plugins :(
I am setting up a forum in our intranet part of the website (for our members - behind login).
Two menu's: 1) Public (for visitors) 2) Menu for registered users only. Registered users are owners and tenants. Registered is the higher access level; owners and tenants are sub levels, with tenants having less access.
I do not want a separate Kunena menu, so the forum will be one entry in the menu or registered users.
I have activated this menu item ('Forum')
-Menu-itemtype = Category list
-Categorie-ID = ;'main category', chosen as standard, with 2 sub categories ('business' and 'leasure') each with 4 or 5 items.
So, good to go? Unfortunately not.
When I cklick the menu (as a registered user) I get the attached cryptic message.
I can not find any topic on how to get rid of this Kuena Profile Information stuff and just have the forum instead. The omline Kunena manual unformtvunately is far from complete, so that is why I'm asking for your benevolence.
Configutration report attached below.
Thanks in advance for your very appreciated help.
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload:
Joomla default template details : cassiopeia_vlietpark | author: admin | version: 1.0 | creationdate: mei 2024
Kunena default template details : Aurelia | author: Kunena Team | version: 6.4.4 | creationdate: 2025-07-09
Kunena template params:
Kunena version detailed: Kunena 6.4.4 | 2025-07-09 [ Git Repository ]
Plugins: None
The following user(s) said Thank You: ssnobben
1 year 2 weeks ago #233870 by Pinkeltje
Time to create page: 0.267 seconds
