Question PHP error warning .........
1 year 3 months ago #233829 by Petley
[15-Aug-2025 09:25:03 UTC] PHP Warning: Array to string conversion in /home/xxxxx/public_html/libraries/kunena/src/Layout/KunenaBase.php on line 319
Any ideas?
1 year 3 months ago #233830 by Pinkeltje
It is a warning and not an error. Your error reporting is set too high. Check your settings in Joomla configuration.
The following user(s) said Thank You: Petley
1 year 3 months ago #233834 by Petley
Replied by Petley on topic PHP error warning .........
Thanks, but is it possible to fo something that will mean that I fo not get the warning?
1 year 3 months ago #233835 by Pinkeltje
Can't reproduce. It must have something to do with error reporting and/or server configuration. Which Joomla and Kunena version are you using? Which Kunena template? Which PHP version?
1 year 3 months ago #233837 by Petley
Latest Jooma 5.3.2 I think, latest Kunena 6.4, PHP is 8.3, template is NTS KBee so not the default.
Thanks Terry
1 year 3 months ago #233838 by Pinkeltje
And the latest KBee for Kunena 6.4?
