- Thank you received: 1
Question Size of kunena/attachments
Any strategies on how one would reduce the size, delete attachments, or whatever?
Rob
Joomla 5.3.3
Kunena 6.3.10
Or in the Backend -> Kunena -> Tools -> Prune Categories you can select a time frame up to which older topics should be deleted. This deletes older topics including attachments.
Yes, I have used this to remove archive categories. However, it does result in errors when running diagnostic. Correcting the diagnostic errors does not seem to cause any problems.
> Backend -> Kunena -> Attachments
Yes, one can do this but there is no way to tell what the impact is, what broken links happen. I did try this and it generated a bunch of diagnostics.
Joomla 5.3.3
Kunena 6.3.10
I have tested it and cannot confirm diagnostic errors. However, it may happen that orphaned entries or dependencies remain in the database. This will be displayed in the diagnostics. Clicking the "Repair" button will remove these entries. You should always have a database backup before performing this action!> Or in the Backend -> Kunena -> Tools -> Prune Categories
This action should also remove the links to the attachments from the message. But if the message only contains an image without text, an empty response remains.> Backend -> Kunena -> Attachments
