Question v 6.3.4, Invalid stats and topic indicators
2 years 1 month ago - 2 years 1 month ago #231956 by Bearsampp
we just upgraded to 6.3.4 and at the same time discovered numerous spam users and topics.  We went thru and banned each user and selected "delete all posts" and now we have every category showing unread topics even though there are no topics in those categories.
1) why were these users able to make spam posts when captcha is enabled and so is the anti-spam tool in kunena ( I forget its name )
2) how can we delete all these invalid topics.
3) how do we fix the broken statistics tool
The stats tool shows divide by zero error when used.
bearsampp.com/forum
Last edit: 2 years 1 month ago by Bearsampp.
2 years 1 month ago #231959 by Leen
hello,
that from " The stats tool shows divide by zero error when used "
comes that there may be errors found look at
Kunena Forum: Tools >Diagnostics
clean up or repair everything here and the message will not appear anymore
With kind regards
Leen
2 years 1 month ago #231960 by Pinkeltje
Did you open Kunena dashboard immediately after installing update?
  1. Captcha doesn't block every spammer unfortunately. You can try installing plugin OSpam-a-not, which may reduce spam registrations.
  2. Did you run diagnostics and repaired tables?
  3. See 2
2 years 1 month ago - 2 years 1 month ago #231965 by Bearsampp
that was the first thing I checked. Everything there passes
[pre]
DiagnosticscategoryOrphanedTEST PASSEDNo issues found! categoryMissingAliasTEST PASSEDNo issues found! categoryWrongAliasTEST PASSEDNo issues found! aliasMissingCategoryTEST PASSEDNo issues found! messageBodyMissingMessageTEST PASSEDNo issues found! messageMissingMessageBodyTEST PASSEDNo issues found! topicInSectionTEST PASSEDNo issues found! topicMissingCategoryTEST PASSEDNo issues found! topicMissingMessagesTEST PASSEDNo issues found! topicMissingPollTEST PASSEDNo issues found! topicPollMismatchTEST PASSEDNo issues found! movedMissingTopicTEST PASSEDNo issues found! movedAndMessagesTEST PASSEDNo issues found! messageWrongCategoryTEST PASSEDNo issues found! messageOrphanedTEST PASSEDNo issues found! attachmentOrphanedTEST PASSEDNo issues found! pollOrphanedTEST PASSEDNo issues found! pollTopicMismatchTEST PASSEDNo issues found! pollOptionOrphanedTEST PASSEDNo issues found! pollUserOrphanedTEST PASSEDNo issues found! thankyouOrphanedTEST PASSEDNo issues found! userCategoryOrphanedTEST PASSEDNo issues found! userReadOrphanedTEST PASSEDNo issues found! userReadWrongCategoryTEST PASSEDNo issues found! userTopicOrphanedTEST PASSEDNo issues found! userTopicWrongCategoryTEST PASSEDNo issues found! ratingOrphanedTEST PASSEDNo issues found! channelOrphanedTEST PASSEDNo issues found! userAvatarOrphanedTEST PASSEDNo issues found! topicsOwnersOrphanedTEST PASSEDNo issues found!
[/pre]
2 years 1 month ago #231966 by Bearsampp
ok, after clearing the cache while tools was open, it allowed the statistics to reset and the main problem has gone away.
Now, using ospam-a-not are there any settings that need to be configured?
2 years 1 month ago #231967 by Pinkeltje
Just install and enable.
Time to create page: 0.245 seconds
