Question tables still in database after uninstalling component
- aimlesslady
The component was installed when using Joomla 3, but we are now using Joomla 4 and do not need the component.
I also see the kunenan Framework in the 'Discover' interface. How do I remove that?
- Thank you received: 2545
However, you should have done this before upgrading to Joomla 4, because if Kunena was not minimum K5.1 beforehand, the installation (migration) to Joomla 4 will not work and cannot be removed in this way.
- aimlesslady
The component was uninstalled while still in Joomla 3. It was probably uninstalled via the System>Manage Extensions, not Kunena Tools.
I am currently using Joomla 4.
What are my options now? Do I install version 6.x? Then uninstall it?
If it can be installed, it is the best way to remove Kunena completely.Do I install version 6.x? Then uninstall it?
However, first create a complete backup of your new website.
- Thank you received: 195
In principle you are right, but the user aimlesslady wants everything from Kunena to be removed completely.Just manually delete all kunena tables from your database if you are not planning to use it in your Joomla 4 site.
