Question Sub-categories are not lining up
- trogladyte
- Junior Member
The sub-categories under the main topic "Aircraft" do not line up with those under "Marketplace" on the front end, but, as can be seen by the image, they share the same place in the hierarchy.
Any idea what's happening?
- Thank you received: 198
so I think you are at menu item marketplace have chosen another menu item have chosen ?
With kind regards
Leen
It could be because a longer text was entered in the category description for one category and therefore the display of all categories in this section was moved slightly forward.
But that is just a guess.
Gindi
www.kunena.org/forum/index
I have KPraxis from 9themestore and it has div's instead of table. No problem at all with layout.
- Thank you received: 2545
Here you can see the difference between categories and subcategories: docs.kunena.org/en/manual/backend/catego...new-section-category
