Question Integrating Shape5 Forte to work with Kunena
2 years 11 months ago #229716 by Josh65
Hi
UserLeen has helped in customizing css so as to get Kunena 6 to operatewith Kunena.
So far have been extremely valuable.
Issue I haveat the moment, is that the post topic is not showing its text area.
I have similar issueswhen trying to update/edit profile
Any ideas  how to correct.
2 years 11 months ago #229720 by Leen
This is really difficult, can you also tell us which colors you have set?
in your Forte template or screenshot like mine
And also if you have created something in custom.css from template and/or kunena Aurelia template
I can then test something
I have this template for the test >> forte Site Template 1.0.7
With kind regards
Leen
2 years 11 months ago #229722 by ruud
Hi, just on a side note: Shape5 is discontinued for Joomla5 so if you are having plans to upgrade to J5 (who doesn't / hasn't already) then you are going to have an issue: www.joomlart.com/blog/news-updates/annou...updates-for-joomla-5
sharing = caring
2 years 11 months ago #229723 by Josh65
Hi Leen,
kunena, custom.css
.list-unstyled {     color: white; } #kunena.layout {     background-color: #00005f !important; } .navbar {     overflow: visible;     margin-bottom: 20px;     background-color: #00007f !important; } .shadow-lg {     box-shadow: var(--bs-box-shadow-lg)!important;     background-color: #0000a0 !important; } .rounded {     border-radius: var(--bs-border-radius)!important;     background-color: #00007f !important; } .dropdown-menu {     border-style: groove !important;     border-color: #7f7f2f;     border-width: medium !important; } #kunena.layout .tab-content {     display: flex;     border-style: groove;     border-color: #afaf4f;     border-width: medium; } .form-select {     --bs-form-select-bg-img: url("data:image/svg+xml,%3csvg xmlns='http://www.w3.org/2000/svg' viewBox='0 0 16 16'%3e%3cpath fill='none' stroke='%23343a40' stroke-linecap='round' stroke-linejoin='round' stroke-width='2' d='m2 5 6 6 6-6'/%3e%3c/svg%3e");     display: block;     width: 100%;     padding: .375rem 2.25rem .375rem .75rem;     font-size: 1rem;     font-weight: 400;     line-height: 1.5;     color: #ffffff;     -webkit-appearance: none;     -moz-appearance: none;     appearance: none;     background-color: var(--bs-body-bg);     background-image: var(--bs-form-select-bg-img),var(--bs-form-select-bg-icon,none);     background-repeat: no-repeat;     background-position: right .75rem center;     background-size: 16px 12px;     border: var(--bs-border-width) solid var(--bs-border-color);     border-radius: var(--bs-border-radius);     transition: border-color .15s ease-in-out,box-shadow .15s ease-in-out; } .input-group:not(.has-validation)>.dropdown-toggle:nth-last-child(n+3), .input-group:not(.has-validation)>.form-floating:not(:last-child)>.form-control, .input-group:not(.has-validation)>.form-floating:not(:last-child)>.form-select, .input-group:not(.has-validation)>:not(:last-child):not(.dropdown-toggle):not(.dropdown-menu):not(.form-floating) {     border-top-right-radius: 0;     border-bottom-right-radius: 0;     background-color: #0b24d3; color: #ffffff !important; } .text-muted {     --bs-text-opacity: 1;     color: #FFEB3B!important; } #kunena.layout .kmsg {     margin: 20px 0;     font-family: "Segoe UI", "Segoe UI Emoji", "Segoe UI Symbol", Helvetica, Arial, sans-serif;     word-wrap: break-word;     background-color: #00119f !important; } .table, .thumbnail {     background: #3c3aa9 !important;     color: #FFFFFF !important; } .table.table th {     background: none repeat scroll 0 0 #3643a3 !important;     color: #FFFFFF !important; } .table>:not(caption)>*>* {     padding: .5rem .5rem;     color: var(--bs-table-color-state,var(--bs-table-color-type,var(--bs-table-color)));     background-color: #225bc3;     border-bottom-width: var(--bs-border-width);     box-shadow: inset 0 0 0 9999px var(--bs-table-bg-state,var(--bs-table-bg-type,var(--bs-table-accent-bg))); } .pagination {     --bs-pagination-padding-x: 0.75rem;     --bs-pagination-padding-y: 0.375rem;     --bs-pagination-font-size: 1rem;     --bs-pagination-color: var(--bs-link-color);     --bs-pagination-bg: var(--bs-body-bg);     --bs-pagination-border-width: var(--bs-border-width);     --bs-pagination-border-color: var(--bs-border-color);     --bs-pagination-border-radius: var(--bs-border-radius);     --bs-pagination-hover-color: var(--bs-link-hover-color);     --bs-pagination-hover-bg: var(--bs-tertiary-bg);     --bs-pagination-hover-border-color: var(--bs-border-color);     --bs-pagination-focus-color: var(--bs-link-hover-color);     --bs-pagination-focus-bg: var(--bs-secondary-bg);     --bs-pagination-focus-box-shadow: 0 0 0 0.25rem rgba(13, 110, 253, 0.25);     --bs-pagination-active-color: #fff;     --bs-pagination-active-bg: #0d6efd;     --bs-pagination-active-border-color: #0d6efd;     --bs-pagination-disabled-color: var(--bs-secondary-color);     --bs-pagination-disabled-bg: #7a838d !important;     --bs-pagination-disabled-border-color: var(--bs-border-color);     display: flex;     padding-left: 0;     list-style: none; } .dropdown-menu.show {     display: block;     background-color: #007f8f !important;     color: #ffffff!important; } #kunena.layout h3 {     font-size: 18px;     color: #ffffff !important; } #kunena.layout #editUser .form-control, #kunena.layout #editUser .custom-select, #kunena.layout #editprofile .form-control, #kunena.layout #editprofile .custom-select, #kunena.layout #editavatar .form-control, #kunena.layout #editavatar .custom-select, #kunena.layout #editsettings .form-control, #kunena.layout #editsettings .custom-select {     width: auto;     background-color: #7f7fff !important;     color: #ffffff!important; } .nav-tabs .nav-link.active, .nav-tabs .nav-item.show .nav-link {     color: var(--bs-nav-tabs-link-active-color);     background-color: #4f4fff !important;     border-color: var(--bs-nav-tabs-link-active-border-color); } .list-group-flush > .list-group-item {     border-width: 0 0 var(--bs-list-group-border-width);     background-color: #4f4fff !important;     color: #cfcfcf !important; } .inputbox, .registration input, .login input, .contact-form input, #jform_contact_message, input, textarea, .validate, select, textarea, input[type="text"], input[type="password"], input[type="datetime"], input[type="datetime-local"], input[type="date"], input[type="month"], input[type="time"], input[type="week"], input[type="number"], input[type="email"], input[type="url"], input[type="search"], input[type="tel"], input[type="color"], .uneditable-input {     border: none;     font-size: 0.9em;     padding: 12px;     background: #4f4fff !important;     color: #ffffff !important;     font-weight: 400;     -moz-box-sizing: border-box;     -webkit-box-sizing: border-box;     box-sizing: border-box;     min-height: 40px; }
I get the same ifi use the default forte style, aswell as my custom one.
custom.css for forte
/* Add your own custom css to this file. You may wish to use css !important calls to override css from the template css files. ----------------------------------------------------------- */ .s5_top_row1_area1 {     background: #00002a !important; } .result__item>* {     margin-bottom: 0;     color: #cfcfcf !important; }.form-horizontal .help-inline, .form-horizontal .input-append, .form-horizontal .input-prepend, .form-horizontal .uneditable-input, .form-horizontal input, .form-horizontal select, .form-horizontal textarea, .form-inline .help-inline, .form-inline .input-append, .form-inline .input-prepend, .form-inline .uneditable-input, .form-inline input, .form-inline select, .form-inline textarea, .form-search .help-inline, .form-search .input-append, .form-search .input-prepend, .form-search .uneditable-input, .form-search input, .form-search select, .form-search textarea {     display: inline-block;     margin-bottom: 0;     vertical-align: middle;     background-color: #34347f !important;     color:#efefef !important } .finder {     max-width: 100%; } .inputbox {     font-family: 'Roboto',Helvetica,Arial,Sans-Serif;     color: #ffffff !important;     background-color: #2c2c7f !important; } .well {     background: #4e5eb1;     -webkit-box-shadow: none;     -moz-box-shadow: none;     box-shadow: none; } body {     color: #fffdfd;     background: #ffffff;     font-weight: 400;     font-size: 1em;     overflow-x: hidden;     line-height: 170%; } h2 {     font-size: 2.1em;     line-height: 130%;     margin-bottom: 20px;     font-weight: normal;     color: #f3ebeb; } h5 {     font-size: 1.1em;     line-height: 130%;     font-weight: normal;     color: #ffffff; } #s5_component_wrap_inner h2 a, #s5_component_wrap_inner h1 a {     text-decoration: none;     color: #18ef8e!important; } h1 small, h2 small, h3 small, h4 small, h5 small, h6 small {     font-weight: 400;     line-height: 1;     color: #FFEB3B!important; } #s5_footer_area1 {     background: #000000;     color: #FFFFFF;     font-size: 0.9em;     padding: 40px;     padding-top: 28px;     padding-bottom: 28px; } #s5_nav li.active, .button, .readmore a, .readon, .s5_ls_readmore, .dropdown-menu li > a:hover, .dropdown-menu li > a:focus, .dropdown-submenu:hover > a, .dropdown-menu .active > a, .dropdown-menu .active > a:hover, .nav-list > .active > a, .nav-list > .active > a:hover, .nav-pills > .active > a, .nav-pills > .active > a:hover, .btn-group.open .btn-primary.dropdown-toggle, .btn-primary, .item-page .dropdown-menu li > a:hover, .blog .dropdown-menu li > a:hover, .item .dropdown-menu li > a:hover, .btn, .pagenav a, .jdGallery .carousel .carouselInner .active, #s5_pos_custom_2, .module_round_box-highlight, .recommended .s5_title, .ac-container label:hover, .ac-container2 label:hover {     background: #b22222 !important; } .readon.readon_grey {   color: #ffffff !important;     background: #9195a7 !important; } #kunena .dropdown-toggle::after {     display: none; } #kunena.layout .collapse { display: contents !important; } tbody, td, tfoot, th, thead, tr {     border-color: inherit;     border-style: solid;     border-width: 0;     color: #ffffff !important; } h4 {     font-size: 1.5em;     line-height: 130%;     font-weight: normal;     color: #ffffff !important; } .table>:not(caption)>*>* {     padding: .5rem .5rem;     color: var(--bs-table-color-state,var(--bs-table-color-type,var(--bs-table-color)));     background-color: #22304a;     border-bottom-width: var(--bs-border-width);     box-shadow: inset 0 0 0 9999px var(--bs-table-bg-state,var(--bs-table-bg-type,var(--bs-table-accent-bg))); } .p-2 {     padding: .5rem!important;     font-size: large;     color: #7fff7f; } #s5_component_wrap_inner h2, #s5_component_wrap_inner h1 { display: none !important; }
2 years 11 months ago - 2 years 11 months ago #229724 by Leen
Hello, I don't really understand where you get all those codes in
/kunena/core/css/custom.css
Normally there isn't much in there and it seems to me that a lot of it has nothing to do with Kunena the template.
but I can't see your website structure so I assume it's there for a reason.
but if I put these codes in /kunena/core/css/custom.css
Trying this here as a test seems to show me something more
/* leen extra */ .s5_h3_first, .btn-link, a, #s5_search_wrap:hover, .s5_icon_search_close:hover, .readon.readon_grey, #subMenusContainer .moduletable a { color: #EEEEEB !important; } #kunena.layout .form-select, #kunena.layout .custom-select { display: inherit !important; background: #626cf2 !important; } a.btn, table.table th { color: #f4efef !important; }
And try the bootstrap-default-min.css
to be restored to old_bootstrap-default-min.css" in template "forte".
I notice here that it worked against me a lot
and also add .css to the kunena template at .rounded
color: white !important;
With kind regards
Leen
Last edit: 2 years 11 months ago by Leen.
