Question Cannot create Navigate to Catagory
Testing on local test site.
joomla 5, and Latest Kunena
If I have cats like
Products
-- Meat
-- Veggies
If I use my template based on forte, when i get to Products it does not list the 2 sub cats, there is an weird icon which if i press it displays the sub cats fr a split second before its removed,
If I use cassiapa template then on same page ( doing a refresh), I now see the two sub cats under neath the products Cat.
ANy odeas as to what is going on, and also how can I force kunena to display the sub cats without having to pressa button.
also is there a current document that covers all the css used in Kunena 6 ( and what there for) , so as to make configuting the layouts etc easier, rather than spending hours trying to fathom out.
Thnx
- Thank you received: 2545
This would not help, as the conflict is to be found in the Joomla template. I always do such a search using the exclusion method by blocking the CSS files one after the other with the browser tool until the error is gone. Then I know the file in which there is a conflict code.also is there a current document that covers all the css used in Kunena 6 ( and what there for) , so as to make configuting the layouts etc easier, rather than spending hours trying to fathom out.
If you have not changed anything in the category settings, it should be this way by default.ANy odeas as to what is going on, and also how can I force kunena to display the sub cats without having to pressa button.
/templates/forte/css/custom.css
and then put this in there as a test
With kind regards
Leen
when I try this
ps
actually this is a new question so next time then please submit a new question
so that everything doesn't get mixed up
With kind regards
Leen
Thanks, that fixed the issue.
Maybe asuggestion for the forum, have a locked catagory on site titled, third party template integration, which has the custom.css settings to get the standard look and operation to work, ie
Shape5 Forte add at end of custom.css
Again thanks for your help
