Question Change kunena widget
3 years 1 month ago #229596 by makitso
Change kunena widget was created by makitso
I need to modify an a widgets file in the folder below.  Is there any way I can do this, e.g. scss, so the changes will not be overwritten by a kunena update?
components/com_kunena/template/aurelia/layouts/widget/login/login
Joomla 6.1.0
Kunena 7.0.3
3 years 1 month ago #229607 by rich
Replied by rich on topic Change kunena widget
Codes in the custom.scss are not overwritten during an upgrade. Custom SCSS
Likewise, custom changes can be created with a template override. Template Overrides | Kunena Docs
