Question Default font size in text editor?
3 years 1 month ago #229374 by Konsider
Hi :)
When someone is composing a message in the text editor, the text is tiny. What controls the initial font size inside the editor? Is this dictated by Kunena's CSS, or is it built into the text editor? Also, is this a custom text editor made by Kunena, or is it part of standard Joomla?
Thanks! :)
3 years 1 month ago #229376 by Leen
the default size of the text is shown
yoursite\media\kunena\core\js\contents.css
line 24.
Maybe you can do something with that?.
And when you create a message, you can choose large and bold formatting in the editor itself,
but I don't think that's what you mean.
With kind regards
Leen
3 years 1 month ago #229377 by Konsider
It seems that Kunena is using CKEditor, but it must install it somewhere differently to the editor section of Joomla, as it doesn't appear there. If I can find where it's installed, maybe there's a CSS related file for the editor?
3 years 1 month ago #229379 by Leen
I found that setting when choosing create new message in kunena.
But maybe in custom.css
.layout .kmsg { font-size: 18px !important; }
can try if that is what you mean (own size of course)
With kind regards
Leen
3 years 1 month ago #229381 by Konsider
Interesting, thanks for the info :) I don't think that's the thing I was meaning though. I mean how to change the default text size within the actual editor itself (see attached image). I know you can manually change the size in this editor, but it would be good if the starting size was larger, so that the size doesn't have to be changed every time. And, I know that once posted, the text size changes to the site's text size... i just would like the text size larger within this editor.
3 years 1 month ago #229383 by Leen
I may still have an option,
but it is in the
yourwebsite\media\kunena\core\js\contents.css
and then increase the font size in body settings but this change only applies when creating a reply or a new message
a quick answer still remains small
With kind regards
Leen
The following user(s) said Thank You: Konsider
