Question Kunena Navbar
3 years 3 months ago #228862 by makitso
Kunena Navbar was created by makitso
HI,
I for the life of me can't figure out to turn on/off the nav bar display (see above , index, Recent Topics, Solved, etc).  I have a basic test Joomla 4 Kunena 6 where it displays correctly.  However, on my development installation I can't get it to display.
Joomla 6.1.0
Kunena 7.0.3
3 years 3 months ago #228863 by rich
Replied by rich on topic Kunena Navbar
Have you moved the kunename menu to another menu? Menu Issues
Or is it a new installation and you did not create the menu? docs.kunena.org/en/basics/installation/installation-k6-0
Please create a Configuration Report
3 years 3 months ago - 3 years 3 months ago #228865 by makitso
Replied by makitso on topic Kunena Navbar
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload:
Joomla default template details : webtrees2 | author: Webtrees Team | version: 1.0 | creationdate: 2023-08
Kunena default template details : Aurelia | author: Kunena Team | version: 6.1.3 | creationdate: 2023-08-10
Kunena template params:
Kunena version detailed: Kunena 6.1.3 | 2023-08-10 [ Git Repository ]
Plugins: None
Modules: Kunena Latest 6.0.2
Joomla 6.1.0
Kunena 7.0.3
Last edit: 3 years 3 months ago by makitso.
3 years 3 months ago #228867 by rich
Change these two menu items (marked red in the picture) to System links -> Menu item Alias and select the Index as the target ( see here ). Then the navigation bar should be available again.
Time to create page: 0.170 seconds
