Question I have a Dark Template and Cannot See Kunena, how to change?
3 years 2 months ago - 3 years 2 months ago #228709 by Josh65
Hi
Running kunena 6.1.2. on localhost
I have a dark (black) template, installed Kunena and although its working, the frontend is also dark, so i cant read anything.
From what i can see by highlighting page it appears as options are all text (pre-2000 look), how to make look modern, ie buttons etc.
I have explored the menus but cant find any options that helps.
How does one start to configure this, i am sure once i can get started it will make more sense.
I have read the documentation page but too much is not in there.
Help appreciated.
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 512M | Max file upload:
Joomla default template details : forte | author: | version: 1.0.5 | creationdate: January 18th, 2023
Kunena default template details : Aurelia | author: Kunena Team | version: 6.1.2 | creationdate: 2023-07-08
Kunena template params:
Kunena version detailed: Kunena 6.1.2 | 2023-07-08 [ Git Repository ]
Plugins: None
Last edit: 3 years 2 months ago by Josh65.
3 years 2 months ago #228713 by 9themestore
Hi Josh65,
I think the main reason is style conflict. However, I need to debug your website to find the correct solution.
Regards,
3 years 2 months ago #228715 by Josh65
Hi
So can't share login
3 years 2 months ago #228724 by 9themestore
Hi Josh65,
I have tried to install the S5 Forte template and Kunena 6.1.2 on my localhost and found the main reason of your issue. When you choose bootstrap dark style, all your text is set to white so you can't see the text on the forum background.
Solutions:
1. You need custom background of the Aurelia template to dark color.
2. Use a kunena dark style template for your website.
Regards,
3 years 2 months ago #228730 by Josh65
Hi
Thanks for checking,
How do I go about custimizing the Aurelia Template, is there any documentation?
3 years 2 months ago #228732 by 9themestore
Follow this docs to custom style for Kunena template.
Time to create page: 0.291 seconds
