Question Integrate Kunena into Joomla search
3 years 2 months ago - 3 years 2 months ago #228551 by michael.lange
Hi!
Is there any known way to integrate Kunena 6 into native Joomla 4 search?
I have tried it with finder aka smart search. But search results have wrong forum URLs. This bug (?) seems to date back to Kunena 5:
github.com/Kunena/Kunena-Forum/issues/6025
www.kunena.org/forum/k5-1-support/153024...%C2%B4t-found#202031
Then I wanted to use the old simple search. I have not found a Kunena plugin for that. So no results from Kunena appear.
Any ideas?
Thanks!
Last edit: 3 years 2 months ago by michael.lange. Reason: Wrong Smily
3 years 2 months ago #228727 by ssnobben
you cant use old simple search with Joomla 4..
3 years 2 months ago #228728 by xillibit
It's possible to use com_search on Joomla! 4 : www.kunena.org/forum/k-6-10-support/1679...k6-1?start=10#228723
3 years 2 months ago #228736 by rich
I have tested our plugin without com_search and get no error message, but unfortunately no search result either.
3 years 2 months ago #228737 by btc
@rich, do you mean "I have tested our plugin WITH com_search..."?
I'm very keen to use com_search with Kunena in J4. xillibit has tried updating it, but it still doesn't work on my website.
Both the Fabrik search and acymailingsearch plugins work well on J4 without any changes from the versions that work on J3. But that's not the case with Kunena.
3 years 2 months ago #228738 by btc
Do you mean, "I have tested our plugin WITH com_search..."?
I'm very keen to be able to use com_search with Kunena. xillibit has tried making some updates, but I still can't get it to work on my development website.
Interestingly, Fabrik and Acymailingsearch plugins both work in J4 without any changes to the versions for J3. But that isn't the case for Kunena.
I've found some advice on how to install com_search on a J4 website that hasn't been upgraded from J3:  fabrikar.com/forums/index.php?threads/qu...h.53721/#post-280966
Time to create page: 0.249 seconds
