Question Problem changing subject
3 years 5 months ago #228277 by Hifi2you
There is a small problem when changing the topic.
Subject The heading is not changed (Red square) when changing the subject, but the "heading" in the posts is changed as it should be (Green square)
In the settings it says that you can change the subject
3 years 5 months ago #228278 by rich
Replied by rich on topic Problem changing subject
The change only applies to the answer. This is not a problem, it is correct, otherwise anyone could change the title of a topic, even if they are not the author.
If the topic author wants to change the title, he must edit the first post, or have the title changed by a moderator.
