Question Disable bb code
3 years 5 months ago - 3 years 5 months ago #228258 by komir
Disable bb code was created by komir
Hi how can disable bb code in text?
Problem is when want to wrote
 I cant, I get instead emoji
Last edit: 3 years 5 months ago by komir.
3 years 5 months ago - 3 years 5 months ago #228259 by Leen
Replied by Leen on topic Disable bb code
not sure which one you want to disable but you could have a look whether it can be done in the kunena template at the bbcode tab.
And have you checked at kunena tools Diagnostics if everything is okay?
And do you also have the problem if you use the default template of joomla instead of helix ?
ps.
and this is how if jou the code write
[b]bold is code[/b]
With kind regards
Leen
Last edit: 3 years 5 months ago by Leen.
3 years 5 months ago #228264 by rich
Replied by rich on topic Disable bb code
This is the code for the smiley cool.png.
Go to Kunena -> Emoticons in the backend and edit this smiley.
Change the code to (or whatever) you want:
8=)
