Question CK Editor - Images appears as text.
3 years 7 months ago - 3 years 7 months ago #227814 by Patrick-06
Hi !
If I drag an image from my computer, it appears in the editor.
If I validate, the images appear as text.
In addition, attached file images cannot be inserted into the message.
- Joomla 3.10.1
- Kunena 5.2.14
- Template : Blue_Eagle 5 : 1.6.8
- CK Editor
Thanks for help.
Patrick
htaccess: Exists | PHP environment: Max execution time: 360 seconds | Max execution memory: 512M | Max file upload: 512M
Joomla default template details : phoca_pix | author: Jan Pavelka () | version: 1.0.0 | creationdate: 25/05/2019
Kunena default template details : Blue Eagle5 | author: Kunena Team | version: 1.6.8 | creationdate: 2022-11-28
Kunena template params:
Kunena version detailed: Kunena 5.2.14 | 2022-12-14 [ Tharsis ]
Third-party components: UddeIM 4.0
Plugins: Search - Kunena Search 5.2.2
Modules: Kunena Latest 5.2.2 | Kunena Search 5.2.2
Last edit: 3 years 7 months ago by Patrick-06. Reason: Config Report
3 years 7 months ago - 3 years 7 months ago #227819 by Patrick-06
Hi !
Here are some screenshots :
[img][/img]
[img][/img]
[img][/img]
3 years 7 months ago #227824 by rich
This happens when you drag the image directly into the text box. Below the editor is a field for dragging and dropping images., this should be used.
The following user(s) said Thank You: ssnobben
Time to create page: 0.151 seconds
