Question Error when user posts
3 years 9 months ago #227477 by lmcclain
I am getting this fatal error when users are posting..."Exception throw at line 668 in file /home/i81rb962hx44/public_html/libraries/joomla/database/driver/mysqli.php with message Illegal mix of collations (utf8_general_ci,IMPLICIT) and (utf8mb4_general_ci,COERCIBLE) for operation '='"
3 years 9 months ago #227478 by lmcclain
Replied by lmcclain on topic Error when user posts
htaccess: Exists | PHP environment: Max execution time: 300 seconds | Max execution memory: 256m | Max file upload: 8m
Joomla default template details : J51_Fedora | author: Joomla51 | version: 1.0 | creationdate: November 2015
Kunena default template details : Crypsis | author: Kunena Team | version: 5.2.14 | creationdate: 2022-12-14
Kunena template params:
Kunena version detailed: Kunena 5.2.14 | 2022-12-14 [ Tharsis ]
Third-party components: UddeIM 3.9
Plugins: Content - Kunena Discuss 5.2.2
3 years 9 months ago #227497 by xillibit
Replied by xillibit on topic Error when user posts
You are a mix on your columns in the database between utf8 and utf8mb4 but all should be in utf8mb4 . The Kunena report configuration should be fixed too because it check for utf8 not utf8mb4
3 years 8 months ago #227584 by lmcclain
Is this something I need a dev for? Not very versed in SQL.
3 years 8 months ago #227585 by xillibit
Did-you enabled debug mode in Joomla! and Kunena and set error_reporting on maximum on Joomla! configuration panel ? Try with that if by posting you get a more detailled error message
Time to create page: 0.163 seconds
