Question PLG_KUNENADISCUSS_DEPENDENCY_FAIL
3 years 10 months ago #227195 by OldCharlie
While preparing Joomla to upgrade from 3.10 to 4.x.x   and making the pre-update changes  Pre-Update Check - Joomla! Documentation
I ran into the following problem: PLG_KUNENADISCUSS_DEPENDENCY_FAIL
How do I fix this?
3 years 10 months ago #227198 by rich
Uninstall it, or deactivate it completely via the Joomla extension manager (Extensions -> Manage -> Manage. For Kunena 6.0 there is an adapted Discuss plugin, which you then have to install.
3 years 10 months ago #227206 by OldCharlie
I can't afford this.   Looks like I will have to find a free extension.
It's $11/month.
Can you recommend another extension for Kunena?
3 years 10 months ago #227207 by OldCharlie
I found the "basic" for Disqus. But I don't want this plugin, all I want is the Kunena. But the error PLG_KUNENADISCUSS_DEPENDENCY_FAIL comes up unless I install Disqus. How do I get rid of the error without having to install Disqus. Or maybe Kunena can't work anymore without the Disqus plugin.
3 years 10 months ago - 3 years 10 months ago #227208 by rich
I'm sorry, I've never dealt with anything like this. I don't know if there are similar free extensions. You might find something here: extensions.joomla.org/
Uninstall the plugin if you don't need it.
Last edit: 3 years 10 months ago by rich.
