Question Joomla / Kunena upgrade
3 years 11 months ago - 3 years 11 months ago #227012 by anonymous01
I made an attempt to upgrade the forum to v.6 and Joomla 4... But I had to roll it back. I have two questions.
1. How do I correctly assign the open_basedir path for kunena? -
Warning: file_exists(): open_basedir restriction in effect. File(/var/www/mstp/libraries/kunena/External/composer/../../../../../src/libraries/kunena/Administrator/Extension/ForumComponent.php) is not within the allowed path(s): (*******************************) in /var/www/mstp/libraries/vendor/composer/ClassLoader.php on line 507
2. My forum has a large number of announcements, including new ones. Immediately after the upgrade, I got an announcement on the main page that was published four years ago. How can I fix it?
P.S. What's going on with the forum, guys? I don't think it's safe. I can't say any more than that...
Last edit: 3 years 11 months ago by anonymous01.
3 years 11 months ago - 3 years 11 months ago #227013 by xillibit
Replied by xillibit on topic Joomla / Kunena upgrade
For that there is a fix for the 6.0.8 developpement version : github.com/Kunena/Kunena-Forum/commit/82...40066666f549ae28182a
I need to investigate
Last edit: 3 years 11 months ago by xillibit.
3 years 11 months ago - 3 years 11 months ago #227019 by anonymous01
Replied by anonymous01 on topic Joomla / Kunena upgrade
Hello.
Thanks, xillibit. But what about open_basedir?
For Joomla it's something like:
/var/www/site_dir:/var/lib/php/session:/var/www/site_dir/tmp:/var/www/site_dir/log
But this is the first time I see that kunena requires its own special path for open_basedir.
This could pose a real security risk to the forum. Heck, there's no PM here and I can't tell you more... However, you don't need my advice.
3 years 11 months ago #227022 by Leen
Replied by Leen on topic Joomla / Kunena upgrade
Hello
maybe you can try this if you can get to your php.ini
stackoverflow.com/questions/51260925/how...low-url-fopen-in-php
With kind regards
Leen
3 years 11 months ago #227028 by xillibit
I have found a fix for it yesterday, it's in place here
3 years 11 months ago - 3 years 11 months ago #227066 by anonymous01
Hmm. This is a critical error. Which should not be in the stable version of the forum... imho. I do not understand how the forum is supposed to work in production, if there is such an unpleasant problem.
How soon is the release of Kunena v.6.0.8 planned?
