Question Quote problem
4 years 2 months ago #225099 by -SD-DELTON-ACI-
I have a problem with my quote button when i click it to quote a post it works but when i submit the post the only thing i see is my answer and not the quote can anyone help me fix this please.
Version 5.29
4 years 2 months ago #225112 by Leen
Replied by Leen on topic Quote problem
Have you tried switching editors in dekunena template?
Can you post a configuration report.
www.kunena.org/docs/en/manual/backend/to...report-configuration
With kind regards
Leen
4 years 2 months ago - 4 years 2 months ago #225125 by -SD-DELTON-ACI-
Replied by -SD-DELTON-ACI- on topic Quote problem
I am using Kinstance Template and there is no setting i can see for Ckeditor.
Last edit: 4 years 2 months ago by -SD-DELTON-ACI-.
4 years 2 months ago #225126 by -SD-DELTON-ACI-
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 512M
Joomla default template details : ALLROUNDER-j1.6 | author: Juergen Koller | version: 1.4 | creationdate: Apr 2012
Kunena default template details : Kinstance | author: Roundtheme | version: 2.0.1 | creationdate: 11/11/2018
Kunena template params:
Kunena version detailed: Kunena 5.2.9 | 2022-06-08 [ Catraia ]
Third-party components: UddeIM 4.0
Plugins: Search - Kunena Search 5.2.2 | Content - Kunena Discuss 5.2.2
Modules: Kunena Latest 5.2.2 | Kunena Stats 5.2.2 | Kunena Login 5.2.2 | Kunena Search 5.2.2
4 years 2 months ago #225128 by Leen
ok i don't know those template i only use the standard kunena templates and Blue-Eagle.
So ask on this Forum where you bought that template?
maybe they know a solution there
www.roundtheme.com/forum/index
With kind regards
Leen
4 years 2 months ago #225129 by -SD-DELTON-ACI-
I would if their forum was not NoticeThe forum is in read only mode.
Strange i am signed in.
Time to create page: 0.160 seconds
