Topics must relate to a currently supported version of Kunena. If you are unsure what is the current supported version of Kunena, please go to the
download
page.
Question How to remove viewed/read and other no used parts?
4 years 3 weeks ago #225019
by uzbaby
How to remove viewed/read and other no used parts? was created by uzbaby
Hello dear developers!
How can I remove or disable these parts of my Kunena 6 Forum (I showed them in the attachment)
1. Read/Viewed
2. Gender
3. Birthday
4. Category Icons column
Thank you
1. Read/Viewed
2. Gender
3. Birthday
Thank you
4 years 3 weeks ago #225035
by Leen
With kind regards
Leen
Replied by Leen on topic How to remove viewed/read and other no used parts?
Have you ever been View on the Kunena Forum: Configuration
Did you check the tab extra to see if there is anything you can do?
or on the other tabs?
Or else the user has to access his Forum account at the front
Profile Edit.
Or are you looking for some kind of CSS persuasion to hide this info?
Profile Edit.
With kind regards
Leen
4 years 3 weeks ago #225039
by uzbaby
Replied by uzbaby on topic How to remove viewed/read and other no used parts?
Thank you
I analized every page in Kunena configuration, searched Kunena Forum before asking question here, but I could not find answer.
Here is my Extra page as you mentioned (in the attachment).
No place to disable viewed or read or gender or birthday.
4 years 3 weeks ago #225041
by Leen
With kind regards
Leen
well I don't see where all this can be diabled
And that of user info I think that the user himself can remove it via the front when he is logged in
With kind regards
Leen
4 years 3 weeks ago #225065
by uzbaby
I cannot ask every user to edit their profile.
I want automatically remove gender, birthday information form the frontend view.
How can I do it from the backend?
4 years 3 weeks ago #225070
by Leen
With kind regards
Leen
I think that this should be done via the database with a special sql command,
but I don't know which sql command.
maybe a kunena developer can post that here
With kind regards
Leen
Time to create page: 0.242 seconds
