Question 404 permission error on all urls with unread in them
4 years 4 weeks ago - 4 years 4 weeks ago #224960 by derekk
Hello
I am getting 404 no permission errors in Kunena
Example  clicking on this or any post in frontend in forum /forum like the first post  forum/for-sale-wanted/1014-first-time-buyer-need-help/unread.html will show 404 no permissions error
Notice the "unread" in the url. All posts are marked as unread and this unread is added to the url when you click on them
The url without "unread"  /forum/for-sale-wanted/1014-first-time-buyer-need-help.html  shows a 404 error
The post is pulled from Kunena in to Jomsocial using the plugin and shows properly /community.html after logging in
it appears to be a permission error rather than a 404  page not found error
which indicates JS has permission but Kunena does not
In forum when clicking on Kunena link you get redirected to forum/for-sale-wanted/1014-first-time-buyer-need-help/unread.html url and then  this permissions error marked 404 You do not have permissions to access this page.
all the urls include “unread”
Are the users settings making these private or changing permission ?
Note: When you search in Kunena backend no messages show /administrator/index.php?option=com_kunena&view=statistics
thank you
Last edit: 4 years 4 weeks ago by derekk.
4 years 4 weeks ago #224973 by Leen
if you disable the search engine friendly URLs does it work?.
With kind regards
Leen
4 years 4 weeks ago #224990 by derekk
Thanks for the reply Leen.
No returns same results.
Is there a method to post secure  private information here?
4 years 4 weeks ago #225000 by Leen
Hello ,
If you look in this editor when creating a post do you see a padlock that is to make something secret
(but I believe that only administrators of this Forum can see what's in it)
You can also make a report and post it here maybe that there is something to discover
www.kunena.org/docs/en/manual/backend/to...report-configuration
With kind regards
Leen
4 years 3 weeks ago #225021 by derekk
Yes I see the padlock icon
The report has two options one is anonymous I pasted the anonymous below because it does not tell you what the difference is in Kunena extension backend they both say exactly the same words "The Kunena reporting system anonymous helps moderators on the Kunena support forum better understand your setup when you're troubleshooting. Paste the contents of this field in your post when requesting help on the support forum."
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 512M | Max file upload: 64M
Joomla default template details : rt_supra | author: RocketTheme, LLC | version: 1.2.3 | creationdate: May 12, 2021
Kunena default template details : Crypsis | author: Kunena Team | version: 5.2.6 | creationdate: 2021-07-25
Kunena template params:
Kunena version detailed: Kunena 5.2.6 | 2021-07-25 [ Melia ]
Third-party components: Jomsocial 4.8.1
Plugins: None
Modules: Kunena Latest 5.2.2
4 years 3 weeks ago #225023 by Leen
I see that your forum is not quite the latest version
the current version is 5.2.9 maybe update kunena first
www.kunena.org/download
With kind regards
Leen
Time to create page: 0.432 seconds
