Question ck editor get private messages running
4 years 3 months ago #224089 by betteryouthanme
Hey guys,
Is there a tutorial out there that explains how to include private messages into ck editor?
Could not find anything on the web. Maybe someone has a link where its explained, at least some basic infos?
Since uddeim is not available for Joomla 4 is there another solid alternative without installing a complete social network component?
Thanks a lot
Two things fill the mind with ever new and increasing wonder and awe - the starry heavens above me and the moral law within me. Immanuel Kant
4 years 3 months ago #224090 by rich
It is not a PN system comparable to Uddeim. If there is a topic, you have the reply button under each post. For example, if I click reply under your post and write something inside the code tags
This message contains secure information
, only you can read it, but no other users. But unfortunately, it doesn't work yet. github.com/Kunena/Kunena-Forum/issues/8998
The following user(s) said Thank You: betteryouthanme
4 years 3 months ago #224253 by betteryouthanme
i see thanks
so basically its a private message to the topic creator only?
or you can select/type a specific user who is allowed to read the message?
4 years 3 months ago - 4 years 3 months ago #224254 by rich
You can write a PM to any user in a topic. Under each message, there is a Reply button. When someone clicks Reply under your post (regardless of where the post is located), the PM is for you.
Example for this topic here:
If you click the Reply button below my post, the private text would be for me.
Last edit: 4 years 3 months ago by rich.
