Question Showing only certain items in statistics frontend?
4 years 6 months ago #223191 by derekk
I need to know how to show only certain items in the statistics at bottom of page?
  •   limit visible stats (bottom of page) to: Total messages, Total subjects, total categories, Total users
Thank you
4 years 6 months ago #223192 by Leen
have you checked if that is not possible?
Kunena Forum: Configuration tab extra
With kind regards
Leen
4 years 6 months ago #223193 by derekk
Yes I tried those settings they either show none or all of them, not specific to each item.
4 years 6 months ago - 4 years 6 months ago #223194 by Leen
if my picture is what you want I think you can/should adjust the statistics widget yourself with the right kunena template (which is in use).
my test example was modified by removing lines from "mywebsite\components\com_kunena\template\crypsisb4\layouts\widget\statistics\default.php".
But with an Update from kunena this will be overwritten again.
I zipped my custom widget file sent as an attachment so you can view it
I have removed these lines from the statistics widget,
55    <li> 56        <?php echo Text::_('COM_KUNENA_STAT_TOTAL_SECTIONS'); ?>: 57        <strong><?php echo (int) $this->sectionCount; ?></strong> 58    </li> 59   <li> 60        <?php echo Text::_('COM_KUNENA_STAT_TODAY_OPEN_THREAD'); ?>: 61        <strong><?php echo (int) $this->todayTopicCount; ?></strong> 62    </li> 80    <li> 81        <?php echo Text::_('COM_KUNENA_STAT_YESTERDAY_OPEN_THREAD'); ?>: 82        <strong><?php echo (int) $this->yesterdayTopicCount; ?></strong> 83    </li> 84    <li> 85        <?php echo Text::_('COM_KUNENA_STAT_YESTERDAY_TOTAL_ANSWER'); ?>: 86        <strong><?php echo (int) $this->yesterdayReplyCount; ?></strong> 87    </li> 97     <li> 98        <?php echo Text::_('COM_KUNENA_STAT_LATEST_MEMBERS'); ?>: 99        <strong><?php echo $this->latestMemberLink; ?></strong> 100    </li>
ps
But maybe you can also use a user.css or custom.css make the items invisible
With kind regards
Leen
Last edit: 4 years 6 months ago by Leen.
4 years 6 months ago #223206 by rich
If you mean the statistics on bottom of the page you need template override.
docs.kunena.org/en/faq/template-overrides
Example with Crypsis:
Copy the default.php from follwing path:
/components/com_kunena/template/crypsis/layouts/widget/statistics/default.php (or your crypsisb4 depending wath you use)
to
/templates/yourjoomlatemplate/html/com_kunena/layouts/widget/statistics/default.php (this path must be created)
Then comment out or remove the unwanted statistics. Then remain this changes after an upgrade.
4 years 6 months ago #223207 by Leen
I've also tried Rich's explanation and it works well too.
So that is also the best solution
so that it is not overwritten with a new kunena Update
With kind regards
Leen
