Question A users post has disappeared?
4 years 6 months ago #223067 by OldCharlie
I don't know what I did but a users post has disappeared.   I was messing the selecting different templates.... Crypsis  This email address is being protected from spambots. You need JavaScript enabled to view it.5.2.82022-01-01 www.kunena.org Crypsisb3  This email address is being protected from spambots. You need JavaScript enabled to view it.5.2.82022-01-01 www.kunena.org Crypsisb4 I toggled between the three templates and now it seems some of the posts from users have disappeared.   Where did they go and how do I get them back?  Or maybe I did something else to lose the posts?   I don't know what I did to lose it!
4 years 6 months ago #223071 by rich
Replied by rich on topic A users post has disappeared?
Crypis is suitable in conjunction with a Joomla bootstrap 2 template,
for Crypsis b3 you need a Joomla bootstrap 3 template,
and for Crypsisb4 you need a Joomla bootstrap 4 template.
But switch between the Crypsis versions removes no posts, you see only a broken layout, if you choose the wrong Crypsis version.
I don' know what you (or a moderator?) did, but maybe you can find this message in the trash.
4 years 6 months ago #223077 by OldCharlie
Which is the default Cypris template.  Maybe if I switch back to that one it will be there?    I looked and there is nothing at all in the trash?
4 years 6 months ago #223088 by rich
Default is Crypsis, it's the system template. But you must use the template, which is adjusted to your Joomla template. I don't know your Jomla template and so I can't suggest, which Crypiss should be selected.
4 years 6 months ago #223129 by OldCharlie
Hi, I can still access the posting by going to 7thheaven.cloud/lindy-alert/general-ques...-alert/6-lindy-alert
But when I try to moderate this from the above link I get the following:
403 Forbidden
You may not be able to visit this page because of:
an out-of-date bookmark/favourite
a search engine that has an out-of-date listing for this site
a mistyped address
you have no access to this page
The requested resource was not found.
An error has occurred while processing your request.
If difficulties persist, please contact the System Administrator of this site and report the error below.
The post is nowhere on my Kunena within my Joomla Website . I've checked the trash and it is nowhere.
Bill Cory
4 years 6 months ago - 4 years 6 months ago #223132 by rich
I called this link and saw that the "General Questions about Lindy Alert" section does not contain a published category. Without a category, there are no posts either. Please check in the category manager to see if the associated category is unpublished.
However, it looks to me like it was a category before and has been changed to a main section. You need to undo that.
Last edit: 4 years 6 months ago by rich.
