Question How to delete a user acount ?
4 years 6 months ago #223023 by GunterPfeiffer
i have Kunena 5.2.8 on Joomla! 3.10.8 with Community Builder 2.7.2 running.
And i like to know what is the best way to delete a user acount ?
Is it possible to let the users do this themselves ?
Or is it better that i do this manually, but in witch order ?
Starting at Kunena or better from Community builder ?
Any advice would be creat.
Best regards
Gunter
4 years 6 months ago #223031 by rich
Replied by rich on topic How to delete a user acount ?
It depends on what the user wants to have deleted. If a user also wants to have all forum posts removed, it is better to do it via Kunena. If a user is deleted before the posts are removed, it is hard to find this posts and can only be deleted one by one.
Better is (backend-> Kunena -> Users -> mark this User and move all his posts to the trash).
If only the account including the profile should be deleted, it doesn't matter if it is deleted via Joomla, CB or Kunena.
I do not know exactly if this is required in the DSGVO, but for that you need an extension that can do this.
The following user(s) said Thank You: GunterPfeiffer
