Question Kunena Forum Package not compatible with Joomla 3 to Joomla 4 upgrade
4 years 6 months ago - 4 years 6 months ago #222722 by krylachek
Software: Joomla! 3.10.8 ; Kunena 5.2.5
We're updating our website to Joomla 4 and it looks like this Kunena Forum Package extension is not compatible with the upgrade. Will this affect our update? Do you have any instructions on how update from Joomla 3 Kunena 5 to Joomla 4 Kunena 6?
Thank you
from Extentions > Manage:
from Joomla! Update:
Last edit: 4 years 6 months ago by krylachek. Reason: I wasn't able to add images in my first attempt to post
4 years 6 months ago #222723 by rich
Please follow these steps, then there should be no problems.  docs.kunena.org/en/basics/upgrade/upgrade-k6-0
The following user(s) said Thank You: krylachek
4 years 6 months ago #222724 by krylachek
Thank you for linking these instructions. Will this allow us to retain all of the posts that have been made on our site before the update, or will they be deleted when we uninstall Kunena on step 2?
2. Uninstall Kunena via the Joomla extension manager (it uninstalls the Forum along whith the Kunena menu)
4 years 6 months ago #222727 by rich
Yes, all posts and topics will be preserved if you uninstall Kunena via the Joomla extension manager, because the Kunena database tables will not be removed. The attachments and the avatars will also be preserved.
4 years 6 months ago #222740 by krylachek
Thanks for clarifying this.
Once our site is updated, we'd like to move our Kunena Forum to a clean install of Joomla! 4 to build our new development site. Is there a procedure for how this is done? Where are these tables located?
4 years 6 months ago #222742 by rich
In principle it is quite simple.
1. export all #__kunena tables and import them into the table of the new site.
2. Do the same with the Joomla user tables (you need these user tables because otherwise you don't have the related users for the forum posts).
3. adjust the prefixes to the new database
4. install Kunena
5. import from the folder /media/kunena the folders avatars and attachments
That's all.
Time to create page: 0.146 seconds
