Question Solution to using Kunena 5.x on J3.10.x using a BS5 template ?
4 years 9 months ago #221968 by modernmagic
Has anyone come up with a workaround for using Kunena 5.x on J3.10.x using a BS5 template ?
I don't care if the Kunena template is a blank slate and I have to style it all.  I just need it to function on a BS5 Joomla-template.
We focus on creating, managing and optimizing Joomla websites so you can focus on your own business
modernmagic.com
4 years 9 months ago #221979 by Leen
I don't understand your question are you looking for a template for Kunena? if so why or for your website?
and what joomla and kunena template are you using now?.
I saw something here with template bs5
www.joomlart.com/member/downloads/joomlart/t4/t4-framework
With kind regards
Leen
4 years 9 months ago #222005 by modernmagic
Specifically I am using Crypsisb4 (which obviously is not BS5 compatible) on a J3 site using Helix Ultimate (which uses BS5).
I am looking for a Kunena-template that works on a Joomla 3 site that is using a Bootstrap 5 Joomla-template.
The issue is that the tooltip breaks the Reply/Actions of Kunena because of a BS4/BS5 conflict.
This is the Console Error:
Uncaught TypeError: $(...).modal is not a function
    at HTMLDocument.<anonymous> (index.php?option=com_kunena&view=category&layout=list&catid=0&Itemid=1120:79:33)
    at u (jquery.min.js?2f99c32ee8ebf2ccd92fe794159ac519:2:27579)
    at Object.fireWith [as resolveWith] (jquery.min.js?2f99c32ee8ebf2ccd92fe794159ac519:2:28337)
    at Function.ready (jquery.min.js?2f99c32ee8ebf2ccd92fe794159ac519:2:30124)
    at HTMLDocument._ (jquery.min.js?2f99c32ee8ebf2ccd92fe794159ac519:2:27307)
(anonymous) @ index.php?option=com_kunena&view=category&layout=list&catid=0&Itemid=1120:79
u @ jquery.min.js?2f99c32ee8ebf2ccd92fe794159ac519:2
fireWith @ jquery.min.js?2f99c32ee8ebf2ccd92fe794159ac519:2
ready @ jquery.min.js?2f99c32ee8ebf2ccd92fe794159ac519:2
_ @ jquery.min.js?2f99c32ee8ebf2ccd92fe794159ac519:2
[Violation] Forced reflow while executing JavaScript took 66ms
modernmagic.com
4 years 9 months ago - 4 years 9 months ago #222013 by xillibit
We have only in Kunena 6.0 (which is still in beta stage) a template which works with Boostrap 5 because it's a specific version build for Joomla! 4.1 and 4.0
For Kunena 5.2 we have templates compatible with Bootstrap 2.3.2, 3.x and 4.x
Last edit: 4 years 9 months ago by xillibit.
4 years 9 months ago - 4 years 9 months ago #222014 by 9themestore
You can clone new template from the Crypsisb4 template and replace the bootstrap data attribute to compatible with Bootstrap 5 and the Helix Framework or T4 Framework. That is solution we are updating for all our templates.
Best regards,
Last edit: 4 years 9 months ago by 9themestore.
4 years 9 months ago - 4 years 9 months ago #222021 by Leen
for the helix ultimate have you already tried the setting as my picture ?.
don't forget to clean the joomla cache
With kind regards
Leen
Last edit: 4 years 9 months ago by Leen.
