Question Hide topic strater from new topic
4 years 11 months ago #220743 by roadside
Hello Kunena users,
I’m a beginner, so my question may be stupid. How do I remove a topic creator from the beginning of a topic?
All the best and Merry Christmas!
Zoltan
4 years 11 months ago #220744 by rich
Which Kunena template use you?
Go in the backend to your Kunena template (tab Features) and choose the profile position left or right.
4 years 11 months ago #220745 by roadside
Jf-simone ()
4 years 11 months ago #220747 by rich
Have you installed the correct template for your Kunena version and is it up to date? It seems to be a template problem. You should contact the manufacturer of the template, I think they can help you better.
