Question Does statistics recount auto run?
5 years 4 months ago #217918 by inspry
Was wondering if the "recount statistics" tool (counting forum topics) automatically runs by itself or only runs when you manually run it in the back-end. Does anyone know? As far as I can tell on our forum, it seems to only be running when we manually run it unless the auto-run is just very long (such as once a month or so).
If they are not auto-running, is it possible for us to make them automatically run? Possibly through a cron job or something of the sort?
Also, does anyone know where these statistics are saved in the database?
Thanks!
5 years 3 months ago #217935 by rich
Unfortunately, I don't know a solution for automatic recount. You need the recount option only if the statistics was not correct counted. In principle, the statistics should be adjusted automatically after each action, such as Total Messages, Replies and so on..., unless your forum will load from a cache.
