Question Crypsis Attachment Error Jquery
  • Trony
  • Trony's Avatar Topic Author
  • Offline
  • Junior Member
  • Junior Member
  • Music and Electronic Devices Designer.
5 years 5 months ago #217854 by Trony
Hi there!
When I try to attach an Image, I have an error 404 Jquer.min when I press In Message and error 400 when I press Remove File and Remove All.
With Crypsis3 and in Debug Mode (Joomla and Kunena), it works.
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 768M | Max file upload: 256M
Joomla default template details : ja_simpli | author: JoomlArt | version: 1.0.5 | creationdate: Jan 15, 2019
Kunena default template details : Crypsis | author: Kunena Team | version: 5.2.5 | creationdate: 2021-05-30
Kunena template params:
Kunena version detailed: Kunena 5.2.5 | 2021-05-30 [ Ligeia ]
Third-party components: UddeIM 3.9
Plugins: Search - Kunena Search 5.2.2
Modules: Kunena Latest 5.0.3
Music and Electronic Devices Designer. Drum and Bass Addict. Creative Mind as Lifestyle. Cat in past Life. Football, Ice Hockey and Snowboard Lover.
5 years 5 months ago #217860 by rich
What happens, if you disable the JCH Optimize?
The following user(s) said Thank You: Trony
  • Trony
  • Offline
  • Junior Member
  • Junior Member
5 years 5 months ago #217861 by Trony
Hello!
JCH is only active for the Guest group.
For Registered users, JCH and other plugins (lazyload images, etc.) are disabled.
5 years 5 months ago #217873 by xillibit
The javascript error that you have on rc2Contentscript.js is related to a javascript not in Kunena and so if it's loaded before the Kunena javascript it blocks the loads of others scripts. Try to disable the extension which loads this script to re-try.
Time to create page: 0.153 seconds
