Question minor issues with layout.
5 years 5 months ago - 5 years 5 months ago #217740 by kominid
Could you pm me for a working link please?
Hi Mods and Admins, Here is my config:
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 768M | Max file upload: 256M
Joomla default template details : dronzColours912 | author:  | version: 1.0 | creationdate: 2021-05-09
Kunena default template details : Crypsis | author: Kunena Team | version: 5.2.4 | creationdate: 2021-04-04
Kunena template params:
Kunena version detailed: Kunena 5.2.4 | 2021-04-04 [ Koios ]
Plugins: None
Can you guys please have a look and see if you could point me in the right direction for these little issues? the login dropdown doesn't work as expected and there are minor layout issues?
Also, is there a way to have separate custom.css for responsive and desktop?
Regards,
Dom
Last edit: 5 years 5 months ago by kominid.
5 years 5 months ago #217762 by 9themestore
Please try to switch to the Crypsis3 or Crypsis4 template and check the login dropdown issue again.
You can user the Crypsis3 if your template are using the Bootstrap 3 CSS Framework or the Crypsis4 if your template loaded the Bootstrap 4 CSS Framework.
Best regards,
