Question Quote fail
5 years 4 months ago #217728 by Hifi2you
Quote fail was created by Hifi2you
Quote fails in google chrome.
When you "Quote" the writing dos´nt jump to next.There is a click on "red enter" and the font also jumps down, but after the topic has been sent and quoted again it is completely wrong.
Incidentally, the red line with the "enter" sign does not work on mobile with android. You can press them but nothing happens and the quote is just a continuation of what is to be quoted
The following user(s) said Thank You: Ozfooty
5 years 4 months ago - 5 years 4 months ago #217768 by Ozfooty
Replied by Ozfooty on topic Quote fail
Totally agree with the author here. Last few Kunena updates have been a joke. Completely stuffed up the quoting function, after latest update it is now even worse. When you quote, even on a desktop or tablet dropping the cursor down you cannot post outside the quoted area and if you quote on a quote, the second persons response becomes part he the original posters post along with yours (the second quote).
It is just a disaster. Same with spell check and paste functions, now laborious compared the previous Kunena forum versions. I am sick of reporting it on here. New version comes out, problems not fixed in fact now even worse. Does anyone know what you are doing here? If you look at my screenshots, didn't even bother to quote in the end just replied.
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 1024M | Max file upload: 100M
Joomla default template details : hot_cars | author: HotJoomlaTemplates.com | version: 3.0 | creationdate: November 2010
Kunena default template details : Blue Eagle5 | author: Kunena Team | version: 1.6.3 | creationdate: 2021-03-10
Kunena template params:
Kunena version detailed: Kunena 5.2.5 | 2021-05-30 [ Ligeia ]    |
Kunena detailed configuration:
Joomla! detailed language files installed:
Third-party components: UddeIM 4.0
Plugins: Search - Kunena Search 5.2.2
Modules: Kunena Login 5.2.2 | Kunena Search 5.2.2
Last edit: 5 years 4 months ago by Ozfooty.
5 years 4 months ago - 5 years 4 months ago #217775 by Ozfooty
As soon as I try to edit my own post which in which I quoted a previous post, it inserts my post into the other persons original post.  For heavens sake when are you going to fix it? It was never broken before you ruined it a couple of updates ago.
5 years 4 months ago - 5 years 4 months ago #217780 by Ozfooty
Another example from my smartphone. As soon as you quote on an already quoted post, the second persons post is embedded into the original post.
5 years 4 months ago #217867 by btc
Replied by btc on topic Quote fail
Because of this problem with quotes, my website is stuck on using K5.1.  I've been testing the various versions of K5.2 on a development site, but so far they're not good enough to move to the production site. I may end up disabling the quote button altogether, which isn't good, but Kunena is an important element of the website, especially because of Kunena Discuss.
The problem doesn't just occur when quoting from an earlier post, it happens when you surround any bit of text with quote tags.
I can work round it if I switch to Source view, but as soon as I revert to Edit view, any text after the end of the quoted section is moved into it. I imagine that the problem with editing lists mentioned in another thread is related.
Is there no possibility of Kunena reverting to the old editor? Or perhaps there's an alternative new editor that would work properly?
5 years 4 months ago #217890 by rich
Replied by rich on topic Quote fail
I'm sorry, but it's not possible to go back, because the old editor is not supported anymore.
We have already reported some bugs to the CKEditor team and are working also hard to  find and fix them ourselves.
You can prevent some errors by not switching back and forth between normal and source mode.
Time to create page: 0.229 seconds
