- Thank you received: 4
Question 401 Unauthorized appearing on logout
Access Control Type: (not set) Options are Community Builder or Usergroups
Access level set to : Registered
User Groups Allowed To Post & Reply set to: a registered usergroup they are not a part of
Thanks!
- Thank you received: 2545
This is logical if access is only allowed for registered users. If the user logs out, they cannot see the content, and he gets this message. If you don't want that, you have to set the access to Public.Update: Actually now I am finding that anyone that logs out of any category is only accessible as a user ends up seeing the 401 Unauthorized message.
It's just not an elegant way for for someone to exit a section of the forum meant for registered users. It would be better to simply redirect to a page that is public.
Or am I misunderstanding what you are suggesting?
I an using CB to control login and registration and can configure the logout redirection, but I am not sure how to get it to work with the Kunena menubar. Is there such an option?
