Question Posts on hold ID #3?
5 years 6 months ago - 5 years 6 months ago #217349 by inspry
Posts on hold ID #3? was created by inspry
Hi all,
So, this issue/question is very code related. Our client wanted us to build a plugin to get a report of all of the "soft-deleted" messages on the forum every month. We went ahead and built it since I figured out that a deleted message has the hold code of 2 in the database.
We sent out the report to them to check over and they told us that some deleted posts are missing from the report. They gave us some message IDs to check in the database, and when I did, the posts come back with the hold code of 3:  www.screencast.com/t/IFD27btOc
I can't seem to figure out what "3" is since I can't even find it referenced in the code.
Does anyone know what that hold ID is? And why is it included with deleted posts? Some of the posts in the database with this hold code, I can't even find on the forum's front-end.
Any help would be appreciated!
Last edit: 5 years 6 months ago by inspry.
5 years 6 months ago #217350 by rich
Replied by rich on topic Posts on hold ID #3?
It's not the same, whether a moderator delete single messages, or a topic with the Moderation button.
Deleted single messages get the ID 2
Messages which deleted with the moderation button "Delete Topic" get the ID 3
Example: Create a topic with 3 messages and delete a single message.
Afterwards delete the complete topic with the Moderation button.
You have now 1 message with ID 2 and two messages with ID 3
It makes sense, because if you restore this topic, it restores only the messages with ID 3.
5 years 6 months ago #217366 by inspry
Replied by inspry on topic Posts on hold ID #3?
So, you're saying that since the starting topic has been deleted, then the messages under it have been deleted as well, which results in the ID of 3?
Just trying to make sure I understand so I can clarify why this is happening to our client.
5 years 6 months ago #217371 by rich
No, it just has to do with how posts are deleted. You have two possibilities to delete messages.
If you delete messages one by one, all these deleted messages have ID 2
And you can delete a complete topic with one click. All these deleted messages get the ID 3
The following user(s) said Thank You: inspry
