- Thank you received: 4
Question Editing 401 Unauthorized Message
401 Unauthorized
You may not be able to visit this page because of:
- an out-of-date bookmark/favourite
- a search engine that has an out-of-date listing for this site
- a mistyped address
- you have no access to this page
- The requested resource was not found.
- An error has occurred while processing your request.
My first guess is language overrides, but not sure. Thanks in advance.
- Thank you received: 2545
I assume you are doing this because of your other posting. If you do change it then surely it makes sense to just add a line that states you may be seeing this as you have logged out.
You can't find this text phrases because your search keywords and the text in the language file are different. The language in the files are translated with HTML codes.
Example:
the same text in the language file
a search engine that has an <b>out-of-date listing for this site</b>
Therefore, you must crop this phrase. You get results with
or
It is the constants:
Maybe this link is helpful too: docs.joomla.org/Custom_error_pages
