Question Kunena with Blue Eagle5 issues
5 years 7 months ago - 5 years 7 months ago #216795 by Vladerp
Hello.
I installed a kunena forum, pretty neat, and to make it better i bought the Blue Eagle5 template. And from here I've met an issues. For the starter - profile settings on frontend are bugged as seen in atachment. All tabs are blank, though the are settings, but just invisible for some reason. For example you can set an avatar by drag & dropping image into blank spot, but still wish it could work normally.
In the attachment #2 this tabs are always collapsed, but they shouldn't be. As it was in prevoius version they were shown, and also there were drop-down button on the right to controll expand/collapse feature. Instead there is just a cross symbol, though it works as inended. But i need this tabs expanded all the
Also polls doesn't work. The tab with the poll is not expanding. Although it seems working when the topic is deleted and visible by super user.
Last edit: 5 years 7 months ago by Vladerp.
5 years 7 months ago #216797 by rich
Replied by rich on topic Kunena with Blue Eagle5 issues
Your first topic is not disappeared. I've only moved your question to the category for Blue Eagle. www.kunena.org/forum/blue-eagle-5
If you have bought Blue Eagle you get automatically access to the category for this template. If it does not work, please send a mail to jelle@*kunena.org (address without star).
5 years 7 months ago #216799 by Vladerp
My client bought BE5 to be exact. From his account. I can't see that topic
5 years 7 months ago #216800 by xillibit
BE5 is Blue Eagle5 or called Blue Eagle, if you client bought Blue eagle you should use his account to have the following category : www.kunena.org/forum/blue-eagle-5
