Question Default font size
5 years 8 months ago #216574 by 2078b54a0a6a52c894ea0efa
I've searched within this forum, but unable to find a definitive answer. I'm using K5.2.3 - how can I set the default font size - from 100 to 150 ?
Thx
5 years 8 months ago #216577 by rich
Replied by rich on topic Default font size
Which size measure for which text do you mean? 150 pixel are 1,27cm.
5 years 7 months ago #216633 by 2078b54a0a6a52c894ea0efa
Size 150 from the font size drop down in the editor.
If I create a new topic or reply to a post it defaults to size 100 - I'd like to change it to 150 instead, so that there's no need to select the text and then change the size.
