Question Edit Categories from backend
5 years 7 months ago #216046 by caw
Hi
I'm trying to edit Categories from backend but I'm getting the following error.
 Call to a member function displayField() on null
Newest Joomla Version, newest Kunena Version, no other Communitiy Plugins. PHP 7.4
5 years 7 months ago #216059 by xillibit
Can-you enable debug mode in Joomla! configuration panel and set debug level on developpement ? And check if the error is more detailled
5 years 7 months ago #216070 by caw
Replied by caw on topic Edit Categories from backend
Deprecated: implode(): Passing glue string after array is deprecated. Swap the parameters in /www/htdocs/w01805fa/fifthwheeler-forum.de/plugins/content/jw_allvideos/jw_allvideos.php on line 73
Call stack
# Function Location
1 () JROOT/components/com_kunena/template/crypsisb4/pages/category/manage/default.php:25
2 include() JROOT/libraries/kunena/layout/base.php:168
3 KunenaLayoutBase->render() JROOT/libraries/kunena/layout/layout.php:80
4 KunenaLayout->render() JROOT/libraries/kunena/controller/application/display.php:116
5 KunenaControllerApplicationDisplay->execute() JROOT/components/com_kunena/kunena.php:104
6 require_once() JROOT/libraries/src/Component/ComponentHelper.php:402
7 Joomla\CMS\Component\ComponentHelper::executeComponent() JROOT/libraries/src/Component/ComponentHelper.php:377
8 Joomla\CMS\Component\ComponentHelper::renderComponent() JROOT/libraries/src/Application/SiteApplication.php:194
9 Joomla\CMS\Application\SiteApplication->dispatch() JROOT/libraries/src/Application/SiteApplication.php:233
10 Joomla\CMS\Application\SiteApplication->doExecute() JROOT/libraries/src/Application/CMSApplication.php:203
11 Joomla\CMS\Application\CMSApplication->execute() JROOT/index.php:49
5 years 7 months ago #216071 by xillibit
The error come from the plugin allvideos which is triggered on Kunena category
5 years 7 months ago - 5 years 7 months ago #216098 by caw
i i change kunena template to crypis error Notice: Trying to get property 'board_title' of non-object in libraries/kunena/controller/display.php on line 339
change back to crypsisb4
/www/htdocs/w01805fa/fifthwheeler-forum.de/components/com_kunena/template/crypsisb4/pages/category/manage/default.php:25
i habe also changed joomla standard theme to protostar...
its a bug in kunena
Last edit: 5 years 7 months ago by caw.
5 years 7 months ago #216106 by xillibit
This last error is coming from frontend but this is something which shouldn't be used. To manage categories you need to go into backend
