Question Edit Categories from backend
I'm trying to edit Categories from backend but I'm getting the following error.
Call to a member function displayField() on null
Newest Joomla Version, newest Kunena Version, no other Communitiy Plugins. PHP 7.4
Can-you enable debug mode in Joomla! configuration panel and set debug level on developpement ? And check if the error is more detailled
Call stack
# Function Location
1 () JROOT/components/com_kunena/template/crypsisb4/pages/category/manage/default.php:25
2 include() JROOT/libraries/kunena/layout/base.php:168
3 KunenaLayoutBase->render() JROOT/libraries/kunena/layout/layout.php:80
4 KunenaLayout->render() JROOT/libraries/kunena/controller/application/display.php:116
5 KunenaControllerApplicationDisplay->execute() JROOT/components/com_kunena/kunena.php:104
6 require_once() JROOT/libraries/src/Component/ComponentHelper.php:402
7 Joomla\CMS\Component\ComponentHelper::executeComponent() JROOT/libraries/src/Component/ComponentHelper.php:377
8 Joomla\CMS\Component\ComponentHelper::renderComponent() JROOT/libraries/src/Application/SiteApplication.php:194
9 Joomla\CMS\Application\SiteApplication->dispatch() JROOT/libraries/src/Application/SiteApplication.php:233
10 Joomla\CMS\Application\SiteApplication->doExecute() JROOT/libraries/src/Application/CMSApplication.php:203
11 Joomla\CMS\Application\CMSApplication->execute() JROOT/index.php:49
The error come from the plugin allvideos which is triggered on Kunena category
change back to crypsisb4
/www/htdocs/w01805fa/fifthwheeler-forum.de/components/com_kunena/template/crypsisb4/pages/category/manage/default.php:25
i habe also changed joomla standard theme to protostar...
its a bug in kunena
