Solved Text direction and map buttons
I can't find any way to do this in the configuration - is it possible to disable the text direction and also map buttons in the editor ?
SUPPORT KUNENA - The numero uno forum for Joomla !!
Also.. at the very bottom of the Crypsis > Bbcode page, there's an option to set the name of the CK Editor skin ('the skin should exist in the skins directory') - I can't find that anywhere, where is that directory located?
Thx again
I've tried it and it works. Maybe you must empty the Joomla and Browser cache.Thanks rich.. although I still can't seem to remove the text direction symbols - any ideas ?
You need this only if you want another layout for the editor. Here you can download Editor Skins. The contained sub folder must be copied to media/kunena/core/js/skins/ and the name of this skin must be entered to the configuration.('the skin should exist in the skins directory') - I can't find that anywhere, where is that directory located?
I've also adjusted the spacing and group order on the edit bar - thanks to this post here:
www.kunena.org/forum/k-5-2-support/16055...s-changes-on-upgrade
Many thanks
