Question External links always open in same window
5 years 10 months ago #215081 by crimle
If you add a link to a topic, it seems to always be opened in the same window (target = _self).
This is ok for internal links.
But external links should (in my opinion) be opened in a new window (target = _blank).
The «link» dialogue does obviously not allow to select the target.
Is there maybe a workaround?
Or how can I change the default target from «_self» to «_blank»?
Thank you and kind regards
Chris
5 years 10 months ago - 5 years 10 months ago #215083 by xillibit
It's a known issue on our side (see : github.com/Kunena/Kunena-Forum/issues/7793 ) i need to make some changes in CKeditor itself to handle that
Last edit: 5 years 10 months ago by xillibit.
The following user(s) said Thank You: crimle
5 years 2 weeks ago #219979 by thefbi
is there a fix for that... since 10 months... ?
5 years 2 weeks ago #219991 by rich
Try it with the BBCode editor, we have reintegrated the earlier editor (you can switch the editor in your Kunena template -> tab BBCode).
