Topics must relate to a currently supported version of Kunena. If you are unsure what is the current supported version of Kunena, please go to the
download
page.
Question How to edit the User-Legend?
5 years 5 months ago - 5 years 5 months ago #214540
by DopiGFX
How to edit the User-Legend? was created by DopiGFX
Hello!
I seached in the Web, but I didn't found the right answer how to edit this.
The first thing I want to change:
I want to remove "Supermoderator" & "Moderator"
The second thing I want to Change is the Color of the other ranks in the Legend and the color of the usernames with that rank.
I'm quite new to web-development, so I need an explanation for newbies
Thanks a lot!
Kind Regard
DopiGFX
Thanks a lot!
Kind Regard
DopiGFX
Last edit: 5 years 5 months ago by DopiGFX.
5 years 5 months ago #214543
by rich
Replied by rich on topic How to edit the User-Legend?
Chang user collors
Use additional this code if you want to hide some ranks.
Example:
Example:
div#kwho .kwho-admin,
div#kwho .kwho-globalmoderator,
div#kwho .kwho-moderator {
display: none;
The following user(s) said Thank You: DopiGFX
5 years 5 months ago - 5 years 5 months ago #214544
by DopiGFX
Replied by DopiGFX on topic How to edit the User-Legend?
Thanks! That helped a lot... first I tought it's not working, but after empty the cache it worked! One little last question: How can I rename or add a rank? Or is there a list where I can find all those possibilities?
5 years 5 months ago #214546
by rich
In principle you can rename all ranks, but also it's possible to create own ranks and own rank images.
Add rank
Add rank
5 years 5 months ago #214547
by DopiGFX
Yea, I know what you mean. But if I add a rank this way, it doesn't appear in the legend but thats what I want.
Lets say I want those all in the legend: Administrator, Moderator, Friend, Super User, User & Banned
Every rank below Moderator shoul only be cosmetically, so they should only be colored and nothing else.
Is it possible to do that?
Btw: Thanks for the quick help!
Kind Regards
Kind Regards
5 years 5 months ago - 5 years 5 months ago #214548
by rich
You can't add your own ranks to the legend. You can only rename already exists rank names in the legend. If you want to change the rank names in the legend, you need language overrides.
Language Overrides
Last edit: 5 years 5 months ago by rich.
Time to create page: 0.255 seconds
